Changes noticed after EKOS SE was fitted
Post by Mr Onion » Thu Jan 12, 2017 12:41 pm
I know this will sound barmy, but then why should I change the habit of a lifetime.
Since Peter fitted the EKOS last year the stylus has been collecting less of a carpet. All that happened was the ITTOK went and EKOS arrived. Same Cartridge, same everything else.
... and yet the Stylus is staying cleaner :smt017
... unless the mods I made to the Radikal are causing it :roll:
Strange but true :smt023
kota
Re: Changes noticed after EKOS SE was fitted
Post by kota » Thu Jan 12, 2017 2:58 pm
maybe the same cartridge is better aligned on the Ekos than it was on the old Ittok. It makes one hell of a difference the muck a poorly aligned cartridge picks up from the grooves than a proper aligned one ...
Fluted black LP12/Kore/Cirkus/Lingo1/aluminium solid base/Ekos1/ESCO Troika, Naim 72K/HiCap/250, NACA5, Neat Motive SE 2
Post by Mr Onion » Thu Jan 12, 2017 5:33 pm
Peter fitted both, so I assume the alignment was perfect for the ITTOK
kota
Post by kota » Thu Jan 12, 2017 7:18 pm
In that case, maybe he could answer that for you :)
Jazz Club
Post by Jazz Club » Fri Jan 13, 2017 7:10 pm
James,
Most likely your old arm wasn't as healthy and as accurate as your new SE.
Were both arms set up by Peter for use with the thicker felt Mat you are using now?
Mr Fixit
Trade Member
Post by Mr Fixit » Sat Jan 14, 2017 12:01 pm
kota wrote:In that case, maybe he could answer that for you :)
Yes, I have implemented some minor earthing changes/improvements to my LP12 set-ups these days. This ensures better continuity throughout. Just another little tweak..... That might well explain Mr Onions findings IMHO.
KR
Peter
Email: peter@cymbiosis.com
Web: http://www.cymbiosis.com
Skype: peteratcymbiosis
Red Chris
Post by Red Chris » Sat Jan 14, 2017 1:12 pm
Perhaps the room has been cleaned? :smt030 :oops:
Currently Cymbiosis LP12 Woodsong Wenge, Klimax Radikal/Chord Sarum T, Keel/A, Khan, Tranquility, Urika/Chord SSA, Aro, sKale, Lyra Kleos SL - Sondek owner since 1982 - the rest is Naim, Chord and Kudos 8)
Post by Coyote Jim » Sat Jan 14, 2017 2:24 pm
Stop playing so many CDs :roll: 8) :smt023
Post by Mr Onion » Sat Jan 14, 2017 2:25 pm
KR
Peter
Ahh, could be Peter. Betted grounding>less static attraction>less fluff attracted
Red Chris wrote:Perhaps the room has been cleaned? :smt030 :oops:
I find cleaning so repetitive. You do all of the cleaning, hoovering and dusting, then 6 months later you have to do it all over again :roll:
Steel City
Post by Steel City » Sat Jan 14, 2017 3:49 pm
James I have found the same thing since I had my Ekos SE fitted by Peter about 3 weeks ago... :smt017 :D
Music was my first love and it will be my last!
