Kandid and Aro
PTplayers
Kandid and Aro
Post by PTplayers » Sun Apr 16, 2017 3:00 pm
Hi , recently purchased a kandid to be mounted on Aro and i have a question about arm leeds .
Am i missing something on how to connect arm leeds from aro to the leeds on kandid , the both seem to be female .
Thank you
Re: Kandid and Aro
Post by evil_C » Sun Apr 16, 2017 3:09 pm
Thank you
If you look inside your Aro box you should find five (including one spare) little gold connectors which plug into the female cartridge and arm leads. If you don't have them, I'd suggest you call Peter Swain at Cymbiosis who seems to have managed to secure sources for many Aro spare parts. It's a great tonearm BTW.
PTplayers
Re: Kandid and Aro
Post by PTplayers » Sun Apr 16, 2017 3:16 pm
Edit :
Found them buried under the the foam in the Aro box .
Yee Ha
PTplayers
Re: Kandid and Aro
Post by PTplayers » Sun Apr 16, 2017 10:28 pm
Paul1 wrote:
Sun Apr 16, 2017 6:41 pm
Edit :
Yee Ha
Thats the easy part over with.
The next step isn't so easy.
When you fit the tag wires to the Kandid make sure they won't drop and touch the record when playing.
Its best to take your time and twist them.
Yes you correct of mounting this cart with wiring .
Tried to find close ups with kandid on aro and none that shows it . :-(
Re: Kandid and Aro
Post by Coyote Jim » Sun Apr 16, 2017 11:29 pm
Not a Kandid but the idea is the same.
Pictures provided by Cymbiosis from another forum.
Tricky 8) :smt023
PTplayers
Re: Kandid and Aro
Post by PTplayers » Mon Apr 17, 2017 12:17 am
image.jpegimage.jpeg. image.jpeg Not a Kandid but the idea is the same.
Tricky 8) :smt023
Thank you very much for the pics . :D
Had it mounted and then tried to make it a little neater then gave up for the day .
Will attempt again tomorrow .
Robert
PTplayers
Re: Kandid and Aro
Post by PTplayers » Mon Apr 17, 2017 12:41 am
Paul1 wrote:
Mon Apr 17, 2017 12:35 am
Robert.
Stop what you are doing before you cause damage.
What you are using are not fit for purpose.
I will get you some help.
Hi Paul , this is not my arm or cart .
PTplayers
Re: Kandid and Aro
Post by PTplayers » Mon Apr 17, 2017 1:35 am
Paul1 wrote:
Mon Apr 17, 2017 1:21 am
Robert.
Best give it back to whom it belongs then.
Its a over complicated mess.
I have an Aro and kandid and was looking for close up pics of that arm leeds .
Attempted but didn't like how wires were so i disassembled .
Jim posted these of another user .
Red Chris
Re: Kandid and Aro
Post by Red Chris » Mon Apr 17, 2017 7:10 am
It might seem silly, but this connection idiosyncrasy slightly puts me off using a Kandid in my Aro :?
Currently Cymbiosis LP12 Woodsong Wenge, Klimax Radikal/Chord Sarum T, Keel/A, Khan, Tranquility, Urika/Chord SSA, Aro, sKale, Lyra Kleos SL - Sondek owner since 1982 - the rest is Naim, Chord and Kudos 8)
Re: Kandid and Aro
Post by evil_C » Tue Apr 18, 2017 6:52 pm
It was, of course, the same with the Troika, for which I believe the Aro was originally designed. Once the leads are appropriately connected and folded neatly behind the cartridge body, there shouldn't be any further issue. Don't give up as I'm sure it will be worth the effort in the end. IIRC Red Kite, formerly of this forum, uses a Kandid / Aro combination in a very high spec LP12.
