Still room for improvement?
Spikes
Post by Spikes » Fri Feb 02, 2018 2:07 pm
Just wondering: can I still improve my LP12? The current setup is:
- Keel
- Ekos SE
- Tangerine Karmen top plate
- sKale weight
- Kandid cartridge
- Urika
- Radikal
- Fluted ebony CH plinth
- Tranquility
- standard Linn felt mat
The only thing I could think of was change the Kandid for an Atlas....
Re: Still room for improvement?
Post by Mr Onion » Fri Feb 02, 2018 2:16 pm
Fluted Stiletto? (I'd have one if the kidney raised enough money)
Steven
Post by Steven » Fri Feb 02, 2018 2:18 pm
I’d be looking at your turntable support if you haven’t done so already
Spikes
Post by Spikes » Fri Feb 02, 2018 3:32 pm
Not sure if I like the looks as much as I like my CH plinth :-)
Spikes
Post by Spikes » Fri Feb 02, 2018 3:38 pm
Good point: currently using a Custom Design WMB1 which is a good fit to the LP12. I bought a Finite Element Pagode a while back. I still have it in the box, because it is way too large for my room. Would there be a better option that is not as huge as the Pagode?
Post by Coyote Jim » Fri Feb 02, 2018 4:06 pm
- Keel
- Ekos SE
- sKale weight
- Kandid cartridge
- Urika
- Radikal
- Tranquility
Fab spec deck I'm a synergetic OCD nut and the things I would do would be put it back to all stock Linn.
Change the SE to an SE1 and that takes care of cosmetics and the old dodgy bias arrangement
Stainless steel top plate and tune the deck without cutting corners.
I've no reason fault the plinth at all :smt007
But I've no confidence with all the variables with third party bits Weights, Tranq etc.
In fact I would have gone Klimax Radikal and forgone the extra bits. :wink:
Most are my own personal reasons but I have very deep and coherent theories about my decisions and can assure you non are down to cost. 8) :smt023
Post by Mr Onion » Fri Feb 02, 2018 5:40 pm
Having seen it "in the flesh" as it were (at Peters) photos do not do it justice. Its far too "2001"ish than you expect
Post by dan steel » Fri Feb 02, 2018 6:03 pm
Play decent music.. :roll:
Red Chris
Post by Red Chris » Sat Feb 03, 2018 11:42 am
Firstly swap the Ekos SE and Keel for an Aro - with sKale and an Aro Keel :smt023 after that Klimax Radikal
Chord Music on the Urika would be wonderful and then a fluted Stiletto
Lyra Atlas would be good but the Lyra Kleos SL would be worth considering.
8)
Currently Cymbiosis LP12 Woodsong Wenge, Klimax Radikal/Chord Sarum T, Keel/A, Khan, Tranquility, Urika/Chord SSA, Aro, sKale, Lyra Kleos SL - Sondek owner since 1982 - the rest is Naim, Chord and Kudos 8)
Red Chris
Post by Red Chris » Sat Feb 03, 2018 2:17 pm
Actually I meant to say Lyra Etna not Kleos - but the Kleos SL is on my personal shortlist for Krystal replacement when the time is right.
