Lingo 4 Installation
Garland
Post by Garland » Wed Oct 03, 2018 3:20 pm
I have the opportunity to acquire a Lingo 4 in great condition. Is there any reason I can't install it myself? ie. special tools, measuring devices etc. I can't find any information on how to go about installing the power supply. I was a professor of electrical engineering and have built my own amps preamps etc. so, the technical ability isn't a problem. Thanks
Re: Lingo 4 Installation
Post by Coyote Jim » Wed Oct 03, 2018 3:29 pm
Hi and welcome.
It's a pretty costly item and is recommended for optimum performance to be installed by a competent dealer.
Having said that there is no reason " other than warranty " why this can't be a home job.
It is certainly much more straightforward than the previous versions to fit as it does away with the rather Heath Robinson method of speed adjustment.
There is a very generously supplied set up guide that goes right through deck and although it covers the Radikal installation it is quite similar.
LP12 set up guide by Cymbiosis
And as far I am aware involves no unique setup tools " especially strobe etc "
Although a suitable jig or table for underneath access is pretty much vital.
Hope this helps and welcome to the happy ship Kabin.
Post by LD100 » Wed Oct 03, 2018 3:34 pm
No reason at all, if a dealer can install it, so can you.
That said, having the installation manual would be very handy. :smt023
As I recall, it also entails changing the motor, so it's not just a simple "change a circuit board" adventure. :smt009
If you run into any problems, you can always ask questions on the Linn Forum...Oh wait...never mind...
If you run into any problems, you can always ask questions here at the Hi Fi Kabin! :smt023 :D
Mr Fixit
Trade Member
Post by Mr Fixit » Wed Oct 03, 2018 4:32 pm
Hi and welcome.
The L4 comes with a comprehensive set of set-up instructions if someone wishes not to have a dealer installation.
Combined with my guide which does not have anything on the L4 yet (due to me being a tad busy recently) if you really want to do it then and provided you have a jig........................
KR
Pete
Email: peter@cymbiosis.com
Web: http://www.cymbiosis.com
Skype: peteratcymbiosis
Garland
Post by Garland » Thu Oct 04, 2018 1:11 am
Thanks guys for the encouragement. As I have a stand, I'm going to go ahead and do it. If I get stuck, I'll post up and ask for help.
Cheers.
Garland
Post by Mr Onion » Thu Oct 04, 2018 9:11 am
Hi Garland
Remember, if you do get stuck a photo is worth a thousand words.
Good luck
Post by Craig Lang » Thu Oct 04, 2018 3:21 pm
Hi Garland
Good luck
Just waiting for one of Jims electrocuted myself pictures :)
