Majik Tonearm
Majik Tonearm
Post by Coyote Jim » Sat Dec 15, 2018 4:16 pm
A new budget "Linn" tonearm has been sneaked in under the radar into the accessory line up.
It's called the Majik and from information around it seems to be a Jelco reincarnation similar to their SA-250-ST that has been discontinued so looks like a buy up or redevelopment rebranding exercise.
Straight tube variant of the SA-250 tonearm, a design found fitted as original equipment on numerous turntables.
Features include a fixed-headshell and calibrated VTF and bias adjustment.
Specifications
Type: static balance straight pipe type
Holding mechanism: one point cross suspension type
Effective length: 228mm
Overhang: 18mm
Mounting distance: 210mm
Mounting hole: 30mm
Bearing friction: 20mg
Suitable cartridge weight: 4 to 12g
Range of height adjustment: 39 to 60mm
No price as yet but the Majik LP12 as it now comes on is the same price as when it had the Project arm on it.
I must say this looks far more business like and makes a starter LP12 look far more appealing than it did.
8) :smt023
Re: Majik Tonearm
Post by Mr Onion » Sat Dec 15, 2018 6:32 pm
Interesting, thanks Jim
Re: Majik Tonearm
Post by dan steel » Sun Dec 16, 2018 12:20 pm
Why don’t they just put an Akito on it. :smt017
Re: Majik Tonearm
Post by Coyote Jim » Sun Dec 16, 2018 12:41 pm
Hi Dan.
It would make the starter cost far too expensive the project that used to come with it retails for about £450 this will probably be about the same.
The Akito is grossly overhyped and priced for what it is it'll never be any old Ekos replacement.
It used to be be the budget arm before the holes in the range left by the Ittok so they had to make it that price £1630 At last price list. :smt005
IMHO. :p
For the money and provenance of the new arm I'd have it instead of the Project or the Akito. :shock:
In fact I used to have it as a Mission 774 LC the budget one of the two they did. 8) :smt023
Re: Majik Tonearm
Post by evil_C » Sun Dec 16, 2018 4:53 pm
Wouldn't a Rega RB300 be a better option?
Re: Majik Tonearm
Post by Coyote Jim » Sun Dec 16, 2018 5:08 pm
Hi Clive,
I've never had a Rega arm but know they are well favoured.
I think the option they're looking at is its the same as linn fit all the way through now.
Majik, or Akito on Majik sub or Kore then the Ekos for Keel.
Majik on a keel would be an interesting one if it fits because the Akito won't fit Keel with its cueing device.
Ooh the possibilities. 8) :smt023
Mr Fixit
Trade Member
Re: Majik Tonearm
Post by Mr Fixit » Mon Dec 24, 2018 3:22 pm
Hi, the new Rega 3 point fitting is different actually and the effective length of their arms is different as well.
I'm not sure why they didn't get together as the Regas are great VFM arms and it wouldn't be that difficult to have made a version with a different effective length one would think!........... Maybe that was the issue as both Project and Jelco seem to have been happy to make these changes! :?
KR.
Peter
Email: peter@cymbiosis.com
Web: http://www.cymbiosis.com
Skype: peteratcymbiosis
