LINN Krystal cleaning advice
- Trade Member
Good evening.
I make this post as a strong advisory notice to all Linn Krystal owners as was suggested to me by Linn Service earlier today.
Following two Krystal cantilever failures which it is likely have been as the result of using Lyra SPT despite careful adherence to Lyra's advice for use. Please stop using any wet cleaning system with this cartridge immediately. It is clear from photographs taken that the cantilevers corroded and subsequently failed during play. Both Krystals were more than 12 months old.
Linn's advice on stylus cleaning remains that we should use the Green Paper.
Any Krystal owner wishing to have some Green Paper if you are not using it already is welcome to contact me for supply FOC. Or their own retailer who will happily supply I'm sure.
Doubtless discussions will be ongoing here and please spread the word.
Best wishes,
Peter
Best wishes,
Peter
Re: LINN Krystal cleaning advice
Hello Peter,
I would be interested to know what further investigations are being performed by Linn to understand how and why these two cantilevers have failed.
Regarding the green abrasive paper, does Linn provide advice on how to use it? The thought of moving the edge of an abrasive sheet close to a narrow walled aluminium tube must surely pose as much a risk as corrosion caused by the use of wet cleaning systems.
Personally I feel more comfortable using the Audio Technica AT637 dry than using green abrasive paper. Is this considered appropriate by Linn?
Thanks and regards,
Clive
Thanks and regards,
Clive
evil_C wrote: ↑Fri Nov 24, 2017 5:43 pm Hello Peter,
Thanks and regards,
Clive
Hi Clive, can I ask if you have been using STP on your Krystal and if so for how long?
Personally I have used STP on mine from day one and it is just over a year old (Sept16) as it worked great on my XX2.
It would be really interesting to find out how many people have been using SPT on their Krystal and for how long.
Then how many have had the cantilever fail (or not!)
Thanks,
Andy.
Cymbiosis LP12 / Ekos SE/1 / Kandid / KRadikal/2 / Keel / Karousel, TP Vulkan, Allnic H1202 Phono, Naim CD5X, Vitus RI-101 Mk2 on Walnut Isoblue, Tellurium Q Black cables into Audiovector M3 Avantgarde Arreté Speakers, Audio Desk Systeme RCM.
Yes I have been using Lyra SPT on my Krystal since new. Although I haven't checked the receipt, I suspect it's over a year old. Mine is serial number 0314. It is quite easy to see when there is a build up of debris on the stylus which cleans off quite effectively with the brush dampened with SPT. I have, I should point out, always used it strictly in accordance with the instructions.
I do not know how to use the abrasive paper to clean the stylus without risk of the edge catching the cantilever (it must be a very delicate operation, after all), so I'd be reluctant to use it. I guess from now I'll just use the AT637 dry, but I don't think it's as effective as SPT.
Although I've never tested it, I would hope that if it failed, then the household insurance should cover the replacement cost as accidental damage, just as it should if the cantilever were caught on a baggy jumper sleeve.
Hi Andy
Here is what mine looked like after a very script adherence to the instructions gently touching the brush to the diamond when damp
Can it really just be the fluid or is it somrthing else ??
Obviously investigation are still ongoing because peter refused to let this be swept aside
Will keep you posted
Regards
Tony
Regards
Tony
Clearaudio concept mc
Naim stageline S with olive hicap
Rega Saturn CD as transport into Theta TLC
then into Marantz HD DAC1
Stax L700 006ts Kimik headphones
Naim Supernait2 naim hi cap DR
Neat Momentum 3i
all supported by mana clamps and racks
Neat Momentum 3i
Derosa wrote: ↑Sat Nov 25, 2017 11:28 am Hi Andy
Can it really just be the fluid or is it somrthing else ??![]()
Regards
Tony
Mine also had that 'look'
Wenge1 wrote: ↑Sat Nov 25, 2017 11:31 amDerosa wrote: ↑Sat Nov 25, 2017 11:28 am Hi Andy
Regards
Tony
Adam,
Prince had the look
Regards
Tony
That looks very suspicious to be blaming the cleaning fluid its rather far up to be used in accordance with instructions IMO.
Peter is a great dealer for trying to get the best he can for his clients after all his reputation is paramount and has had invaluable input regarding upgrades to further develop equipment.
" Keel for Aro " and the Ekos SE/1 headshell access all in the name of keeping the vinyl enthusiast happy and accommodated.
Many other projects aside but has a great ear for the client requirements.
Fine line to tread.
Certainly a fine line to tread but Linn must also realise that customers have choice and can elect to spend their hard earned money anywhere they choose.
The Krystal is indeed a fine cartridge but there are also many others in that price band that are worthy of owning.
Poor press on that cartridge and/or the customer service could actually impact on the dealer sales of the Akurate LP12 !!!
A fine line indeed ......
“That looks very suspicious to be blaming the cleaning fluid its rather far up to be used in accordance with instructions IMO.”
Check out what looks to me like a whole starting in the middle of the cantilever
although I am of course no expert I could be completely wrong
Neat Momentum 3i
Neat Momentum 3i
In my totally un expert opinion that looks like a fracture due to brittle metal.
Regards
Tony
Tony,
What is the distance of the fracture from where the cantilever emerges from the cartridge body? Is the flat part I see at the top of the picture actually the end of the cantilever?
The same question to Adam. Do you have a similarly magnified photograph of your failed cantilever? I'd like to be able to compare the two. I would also like to ask a metallurgist I know to have a look at the photographs.
Thanks,
Clive
I have just checked the receipt for my Krystal cartridge and was surprised to find that I had actually purchased it in January 2016, so it's approaching two (2) years old. Typically I have been using Lyra SPT after each playing session.
Hi Clive
the top of the picture is where the stylus SHOULD be
You can just make out the cartridge body at the bottom right of the photo
(Ps I only used spt at the most 30 times and it had 300 hours on it according to my diary )
Regards
Tony
Regards
Tony
Neat Momentum 3i
Neat Momentum 3i
Neat Momentum 3i
Neat Momentum 3i
Good luck.
If only everyone lived in Scotland where the water is soft and Free.
I sense an opportunity.
My SPT came free my Lyra Kleos
Cymbiosis Tangerine LP12 - Stiletto Skorpion Eklipse - Karousel Klimax Radikal 2/Chord Sarum T, Keel/A, Urika/Chord Sarum T, Aro, sKale, Lyra Kleos SL - Sondek owner since 1982 - the rest is Naim amps and Kudos speakers
Having been a retailer for a number of years items that come free are generally included in the price.
Retail is not a charity.
Looks like a chewed up drinking straw
Doesn't look like the super cleaning formula has done much either.
That’s because I only used it on the diamond as instructed
Neat Momentum 3i
Neat Momentum 3i
That's why I said it.
evil_C wrote: ↑Sat Nov 25, 2017 9:44 am Yes I have been using Lyra SPT on my Krystal since new. Although I haven't checked the receipt, I suspect it's over a year old. Mine is serial number 0314. It is quite easy to see when there is a build up of debris on the stylus which cleans off quite effectively with the brush dampened with SPT. I have, I should point out, always used it strictly in accordance with the instructions.
Thanks for the reply Clive.
Sounds like yours is as old as mine, just over a year.
I am wondering if we have been using SPT from day one whether the damage is already done and reverting to a dry cleaning method won't make much difference?
Maybe only prolong it?
Hi Clive,
Only saw this post after replying to your previous post.
Well your Krystal seems to be holding up very well considering you have been using SPT on it for so Long!!
Maybe ths SPT isn't causing the cantilever to shear after all.
- Trade Member
Exactly and this thread was extracted by the Mods and re-named. The issue as I have said I believe is/was with fluid cleaners on these cantilevers as far as we can tell at this stage.
More research needs to take place first.
Peter
Reason: edited in light of new topic title
