Signature and avatar
If you have any questions or problems on using the HiFi Kabin, please post them here
Billz
Post by Billz »
I am a new member here. How do I create a signature and add an avatar?
Cheers, Bill.
The man with no Naim.
Main System: Linn Selekt Edition/Organic Power Amp - K400 - Akudorik (passive) + SVS3000 Sub.
Second System: Linn SekritDSM- K200 - Kans mk2.
Re: Signature and avatar
Billz wrote: Fri Sep 21, 2018 5:57 pm Hi,
Cheers, Bill.
Hi and welcome.
Click on your name then look for edit profile then there is a list and edit signature and edit avatar is in there.
Just upload your image of choice then your good to go.
Hope this helps. 8) :smt023
Its in your UCP
Fluted Afro LP12, Khan, KEEL, Karousel, Urika, Radikal-2 K, EKOS SE/1, sKale, DVXX-2 A, Tangerine Audio Revolver,
Billz
Post by Billz »
Thanks guys. I did look in there and and couldn’t find the options. Maybe I need to look a bit harder next time. It’s in my nature to crack on with things and then after getting nowhere after about an hour, reading the instructions. Done it all my life :D
Just keep hitting it. It'll either work, or not (in which case its buggered anyway :roll: )
Billz wrote: Fri Sep 21, 2018 6:58 pm Thanks guys. I did look in there and and couldn’t find the options. Maybe I need to look a bit harder next time. It’s in my nature to crack on with things and then after getting nowhere after about an hour, reading the instructions. Done it all my life :D
Think you've found it now your on your second avatar.
8) :smt023
