Which are you referring to?
Kudos Klub
Re: Kudos Klub
Re: Kudos Klub
it took a while to upload the attachment, I think. look at my post again
Main: LP12, Selekt, 3xmajik-I, aktiv Kabers.
Bedroom: Wiim Pro Plus, Tundra 2.5, Kan II’s.
Art Studio: Genki, Kairn, 5105, Kabers.
Re: Kudos Klub
Ahh yes, that finish was discontinued because of production issues but was the finish on the pair I demoed and would have got if Icould. They were bought by a fellow kabineer, lucky duck!
Re: Kudos Klub
That was no gentleman - that was me . I fell in love with the speakers before I had even heard them , even more in love after the demo. That was seven years ago and I still love them.
John
Melco N1A, Akurate DSM, Akurate EXaKtbox6 Katalyst, Silvers, Akurate 4200, K400, Kudos Super20A
Re: Kudos Klub
That was me. I got the Santos Rosewood finish speakers you demoed. Different grain pattern to those in the pic a couple of posts above but the wood finish is the same and looks stunning. It was a 'special' as it was expensive and the wood became harder to ethically source.
Amp - Chord Ultima Integrated
Re: Kudos Klub
Give them that system pic Adam.Wenge1 wrote: ↑Thu Aug 22, 2024 10:45 am.
Re: Kudos Klub
.Coyote Jim wrote: ↑Thu Aug 22, 2024 10:52 amGive them that system pic Adam.Wenge1 wrote: ↑Thu Aug 22, 2024 10:45 am.
Not the best pic and you will have to excuse the cable dressing.
Re: Kudos Klub
Lovely system and speakers Adam.Wenge1 wrote: ↑Thu Aug 22, 2024 10:57 am.Coyote Jim wrote: ↑Thu Aug 22, 2024 10:52 amGive them that system pic Adam.Wenge1 wrote: ↑Thu Aug 22, 2024 10:45 am.
Re: Kudos Klub
.Coyote Jim wrote: ↑Thu Aug 22, 2024 11:05 amLovely system and speakers Adam.Wenge1 wrote: ↑Thu Aug 22, 2024 10:57 am.Coyote Jim wrote: ↑Thu Aug 22, 2024 10:52 amGive them that system pic Adam.Wenge1 wrote: ↑Thu Aug 22, 2024 10:45 am.
Re: Kudos Klub
That’s a nice veneer on your S20s, Adam. It won’t be too long now before I can get mine set up (not as nice as yours though).Wenge1 wrote: ↑Thu Aug 22, 2024 10:57 am.Coyote Jim wrote: ↑Thu Aug 22, 2024 10:52 amGive them that system pic Adam.Wenge1 wrote: ↑Thu Aug 22, 2024 10:45 am.
Re: Kudos Klub
.evil_C wrote: ↑Thu Aug 22, 2024 11:25 amThat’s a nice veneer on your S20s, Adam. It won’t be too long now before I can get mine set up (not as nice as yours though).Wenge1 wrote: ↑Thu Aug 22, 2024 10:57 am.Coyote Jim wrote: ↑Thu Aug 22, 2024 10:52 amGive them that system pic Adam.Wenge1 wrote: ↑Thu Aug 22, 2024 10:45 am.
Cheers Clive - Yours will sound just as good ..........
Re: Kudos Klub
He’s going to use a Supernait 3Wenge1 wrote: ↑Thu Aug 22, 2024 12:22 pm.evil_C wrote: ↑Thu Aug 22, 2024 11:25 amThat’s a nice veneer on your S20s, Adam. It won’t be too long now before I can get mine set up (not as nice as yours though).Wenge1 wrote: ↑Thu Aug 22, 2024 10:57 am.Coyote Jim wrote: ↑Thu Aug 22, 2024 10:52 amGive them that system pic Adam.Wenge1 wrote: ↑Thu Aug 22, 2024 10:45 am.
Re: Kudos Klub
Coyote Jim wrote: ↑Thu Aug 22, 2024 12:24 pmHe’s going to use a Supernait 3Wenge1 wrote: ↑Thu Aug 22, 2024 12:22 pm.evil_C wrote: ↑Thu Aug 22, 2024 11:25 amThat’s a nice veneer on your S20s, Adam. It won’t be too long now before I can get mine set up (not as nice as yours though).Wenge1 wrote: ↑Thu Aug 22, 2024 10:57 am.Coyote Jim wrote: ↑Thu Aug 22, 2024 10:52 amGive them that system pic Adam.Wenge1 wrote: ↑Thu Aug 22, 2024 10:45 am.
Bunch of Naim Boys .........
Re: Kudos Klub
This is the system in my living room, the Akurate DSM and Melco are in the dining room next door
Living Room by John Payne, on Flickr
John
Re: Kudos Klub
SIMPLY STUNNING!
ae111sr wrote: ↑Thu Aug 22, 2024 9:17 pmThis is the system in my living room, the Akurate DSM and Melco are in the dining room next door
Re: Kudos Klub
This may sound mad but...
The Super20s can be run either passive, using the bottom connectors, or Exakt using the top ones. This bypasses the crossover. No internal adjustment is necessary, unlike my old 140s.All well and good.
First question is, when run passive the top ones are shown in the wiring guide connected to another set of connectors below them using little metal hoops. Why? What is the second row connected to? Is this really necessary?
Second question is the mad one and depends on the answer to the first. Can both be connected at the same time? ie. can they be run active in one system, and passive in another? Not at the same time/concurrently but eg. stereo system actively, AV system passively?
Re: Kudos Klub
The passive crossover is physically between the passive input and the passive outputs, so the links connect the crossover outputs to the drive units. Unplug the links and you can then actively connect the amplifiers directly to the drive units. Used passively without the links will result in no sound.
Only if you want lots of fireworks and smoke from the amplifiers and speakers
Fluted Afro LP12, Khan, KEEL, Karousel, Urika, Radikal-2 K, EKOS SE/1, sKale, DVXX-2 A, Tangerine Audio Revolver,
Re: Kudos Klub
Right, thanks. Should have seen Passive Outputs!Mr Onion wrote: ↑Mon Sep 02, 2024 9:56 am
It was just a passing fancy to find a way of getting my left speaker further out from the side wall. Back to the drawing board. Was thinking a pair of b&w m1s, nice and small, but the stands foot is still pretty wide.
Re: Kudos Klub
Doesn’t matter what speakers you have the positioning is very poor.timster wrote: ↑Mon Sep 02, 2024 10:03 amRight, thanks. Should have seen Passive Outputs!Mr Onion wrote: ↑Mon Sep 02, 2024 9:56 am
Same problem for all.
Re: Kudos Klub
Perhaps you could put some silicone bungs in the unused sockets to prevent accidental use.Mr Onion wrote: ↑Mon Sep 02, 2024 9:56 am
DG…
One box is the future…
Main; Linn Selekt DSM: Edition Hub (Utopik / Organik) — Kudos Titan 606 (Active) — Kudos KS-1 — Netgear GS105 — CatSnake Ethernet — TP-Link Media Converter — MSHD / Supra Power Cable — Focal Elear — Dedicated Hi-Fi Mains
Office: PC — SMSL SU-1 — SMSL SA300 — Q Acoustics Q2010i — QED Interconnect / USB / Speaker Cables
Re: Kudos Klub
Good idea. Better if Kudos made it plain in their documentation
Re: Kudos Klub
I've 'only' owned 20A's and mine have the crossover that can't be bypassed
Re: Kudos Klub
Re: Kudos Klub
Seen a couple of mentions that the Kudos 20a and 10a have been retired? Do we know if Kudos has any plans to refresh them or are they just focusing on the Titan's now?
Looking at the new Linn 119 and 150 the Kudos stuff just looks more appealing to me now. Specifically as replacements for my M140 and Katan's.
Study: Genki | Selekt Edition: Twin Organik Amped | 2xK400 | Exakt Katan | Exaktbox Sub | BK P12-300SB-DF
Lounge: Rega P1 | Akurate System Hub Utopik | Akurate Exaktbox Katalyst Utopik | 8xLinn Silver | 2xAV5125 | 4xK400 | Exakt M140
Roon: Lifer | NAS: https://www.truenas.com
https://www.last.fm/user/silkie_uk
