Kabin Update (again)
I know its only been two days but a bug has been found in the previous version that could screw up group membership. Please can you check that you have access and can post in the restricted areas that you could before.
Heads Up (view and post)
Emporium ( start new topic)
Free For All (view and post if you have selecting the option yourself)
There is no need to actually post, just create a topic and preview it. If you can do that then the permissions are still correct. If you come across any errors, please post them here.
I will also send a PM to KAOTM members and would be grateful if you could reply
Re: Kabin Update (again)
I can read your message (obviously
) but I dont see Heads Up any more.
Mark
Mark
Oops forget that. Heads Up is were its alwyas been. Must need new specs
No problems here all good.
Thanks Mark, the permissions looked correct but I have reset them anyway so please can you check again
Just seen your later post, glad its all OK, and have a voucher for 10p off a pair of new specs
Without actually posting to each area, it looks like I have full access to be able to do so.
Thanks all, it looks like we escaped the 'bug' that other Board Owners have reported.
... unless you know different that is
Heads Up - YesThe Kaptain wrote: ↑Fri Mar 18, 2022 9:43 am I know its only been two days but a bug has been found in the previous version that could screw up group membership. Please can you check that you have access and can post in the restricted areas that you could before.
Emporium - Yes
Free For All - Don't use it anymore so haven't checked.
Replied to KAOTM
It's all Kabintastic ...........
Heads Up and Emporium, no problem. Never used Free For All.
Cheers,
‘troll
Cheers,
‘troll
Klimax Exakt...and an LP12
Everything is fine in the pool.
Thanks for checking everyone, I think we escaped the worst of the error.
