Its Me asking for help again
Having swopped my DSM from my old DS-I to a DSM (HDMI version) and getting my 6100 back repaired I have set up the system again. So what's my problems.
1. The music is played in Alphabetical order (and shown in Kazoo that way) but on the NAS it is in track order. How do I correct this.
2. When playing the display only says Artist and doesn't scroll the track name. I have set up Scroll on new track in Kinsky.
Who will come to my rescue (yet again)?
LP12 (now with the special Peter Swain magic touch and a Kore and T-Cable) for analogue, Majik Aktiv System for digital
A life is like a garden. Perfect moments can be had, but not preserved, except in memory
Live Long And Prosper
Re: Its Me asking for help again
Not me I'm afraid, but I am sure someone here will know
Hi Grim I’ll try to help but unfortunately I powered my system down and I’ll have to work from memory.
First I’ll state the obvious, pick the album that is showing alphabetical and check folder and files using MP3tag. Ensure that the track numbers are in the column track number. I’m not sure about this bit but also worth checking the number is in the file title for example it should look something like this
01 - 01 - grimreaper_This Song_LLS.flac.
01 - 02 - grimreaper_secondsong_LLS.flac
Now the niggly bit. I think there is somewhere on Kazoo where you can change from numbers to alphabetical. Open the…
Try changing some of the options on there.
I know I had this problem once and it was a quick fix but I dammed if I can remember the fix but something in the back of my mind is to uninstall both Kazoo server and Kazoo interface. I would try the interface first, if that fails then try the server.
Let me know how you get on. As I said previously good to hear from you and hope you're well.
Sorry for not replying sooner Scooter. I was waiting for a repair to my 6100 which is now done. Working ok now. I think it was something in Twonky on my QNAP and I corrected that.
Are you using uPNP AV as your source, rather than Playlist?
‘troll
‘troll
Klimax Exakt...and an LP12
