iThing glitch
If you want to know something or have a problem, look here first
iThing glitch
Post by The Kaptain »
If you have updated your iThing over the past couple of days you may well be experiencing strange styling errors when you are replying to a topic or PM
Using an emoji at the end of a post or sentence it just appears randomly on the page meaning you have to copy and paste it to put it in the proper place then delete the wrong one. Quotes and previous posts seem to tag on too.
It doesn't just happen here but appears to effect all phpBB boards. Its all down to Apple mucking up their code and there is nothing I can do about it.
I suggest that you report it to Apple so they are aware of the issue and hopefully find a fix quickly.
... or just use a REAL computer :p
Re: iThing glitch
phpBB have implemented a fix to solve this issue which I have added to The Kabin. You will need to purge your browsers cache in order for the fix to work for you.
