Radikal Reset Radikal 2
Much easier than the old Rad 1 method.
Re: Radikal Reset Radikal 2
Thanks Jim, nice find. Copied to the Reference Library
Mr Onion wrote: Tue May 02, 2023 4:28 pm Thanks Jim, nice find. Copied to the Reference Library
It was top secret around the forums but was discovered at Source First. :smt005
What happened to the discussion under this thread?
As a further question, when the advice (above) refers to the button on the deck, does this mean the start/stop 33/45 switch?
Also, wouldn’t you have to push the button on the back of the Radical TWICE? Surely if you only press it once it will select the mute function?
you replied to the topic the Reference Library
Mr Onion wrote: Thu May 11, 2023 9:38 am you replied to the topic the Reference Library
Mind you I can understand how Clive ended up replying in two separate places since the thread titles are almost the same. It did not occur to me either that the same topic was in two separate place :? I'm now not sure where the conservation should take place - not that I could add anything to it ....... :smt023
