HumminGuru Ultrasonic RCM
https://humminguru.com/pages/hg01
Looks very interesting, especially as its something like 25% the cost of other ultrasonic cleaners
I've read the reviews, seen the videos, and am quite tempted. Has anyone seen/used/owns one?
The 2 big advantages I can see is:-
1) Noise level
2) You can set it to automatically clean a record while you are doing something far more important (like listening to one you have just cleaned)
EDIT:- Forgot the purchase link, £468 from Juno Records Cheaper than importing it yourself and paying the VAT and Duty on landing
Re: HumminGuru Ultrasonic RCM
Temptation won, the order is in place.
If you are thinking of buying one, click the 'better price' link. I saved £26 for 60 seconds work, which meant that the cleaning fluid was free. Just need to get some Distilled Water from my Pharmacy
Mr Onion wrote: Wed Jun 21, 2023 10:10 am Just need to get some Distilled Water from my Pharmacy
5l for £6-35 picking it up tomorrow or Friday
Just trying out the HumminGuru on some original somewhat noisy albums.
Followed by
Solitude Standing has marginally improved, Diamonds and Rust (a charity shop purchase) has changed beyond recognition. Not only is the vinyl totally silent (there was a fair bit of surface noise previously) but the recording has also improved. "throwing the window wide open" and all the other cliches.
FYI they had been previously cleaned on the Okki Nokki, probably 3 or 4 times each . Whether the HumminGuru would achieve this improvement without the ON's help I don't yet know. Lots more experimenting to do
A full review will follow in due course
This is very interesting, James. Do the records come out dry, or do they still need to air-dry as with the ON? Is there any risk of danger to the discs?
Thanks,
Clive
Totally dry here on a 5min drying cycle, although that depends on humidity etc in which case there is a 10 min drying cycle.
The only danger to records that I can think of would be an excessive warp making it hit the guides, but they would probably be unplayable anyway
