Coyote Jim wrote: ↑Sat Jul 08, 2023 1:51 pm
A man told me a long time ago that if it was meant to taken on and off it would have a handle in the middle.
If it was meant to be kept on then it would bloody well stay up so you can change the record safely
Coyote Jim wrote: ↑Fri Jul 07, 2023 9:24 am
The hinges, also machined from aluminium, forgo typical dust-cover behaviour (ie, locked in the up position, or shut) and keep it at the angle you desire.
Thinking about it, I'm a bit dubious this is a good idea.
Imagine you set the lid 1 inch above the down position, even if the hinge itself is strong enough, that is a lot of force to apply to the screws holding them to the base, be a shame if it ripped the threads out on your 50K turntable.
Turntable - Fluted Walnut LP12, Cirkus, Kore, trampolin, Ittok LVII, Lingo 4, Krystal.
Amplifier - Arcam A32.
Speakers - Spendor S-3/5.
CD Player - Linn Genki.
Tuner - Quad FM 4 (with output stage mod.)
Cables - Naim NAC A4.
Support - Sound Organisation.
Common sense should prevail it’s either up or down no need for anything else.
I just read what I said.
Mr Onion wrote: ↑Sat Jul 08, 2023 1:58 pm
If it wass meant to be kept on then it would bloody well stay up so you can change the record safely
I’ve never experienced this problem on either of the LP12s I’ve owned (touches wood). I’ve had the current hinges since 1996 or thereabouts.
Indeed, I've never had the lid try to move on me without my explicit order, I replaced the lid when I purchased the Ekos 2 around 2000...so about 23 years of trouble free Linn hinge service.
The Grand Old Duke of York
He had a Sondek 50
and he lifted the lid all the way up
and it stayed there, how nifty.
And when it was up it was up
and when it was down it was down
and when it was only half way up
it stayed there as well, yes really
(well, it almost scans)
NAIM CD 5si with Marigo Lab Aida CD Mat ThePre, ZAP 250, Kudos Super 20's
I agree with CJ, it looks like a easy change with the stock hinges
seeing the hinge tongue still in the vertical position makes me wonder if these are friction hinges (or photographic licence)
I would have done it like this, with rounded plinth and lid corners – more distinctive (different from the standard LP12), and more in keeping with the Apple design ethos.
LP12 (Tiger Paw Stratos, sKale; Karousel, Keel, KRadikal, Ekos SE, Exakt 2, Lyra Etna SL); Klimax NG DSM; Exakt Katalyst Akubariks.
Great picture mod Vincent.
I’d have thought maybe only rounding one side of the Keel too and leave where I’ve circled square.
All akademik now they’ve burnt the cakes.
Thats a much better look Vincent, although I agree with Jim, squared corners on the armboard next to the top plate would make it look even better
If the plinth is laminated beech, I can’t help thinking of the Booplinth, which was similarly laminated, but with layers of bamboo. I wonder how that would compare?
I assume the top plate of the LP12-50 is machined like the Tangerine Karmen. Does anyone know? This I suspect would contribute significantly to any sound improvement. I wonder if Linn will offer a square cornered version as an upgrade for conventional LP12 plinths?
I agree, looks much better. When are you getting Head Hunted by LINN?
The views and comments posted in these fora are personal and do not necessarily represent the those of the Management of HiFi Kabin.
The Management of HiFi Kabin does not, under any circumstances whatsoever, accept any responsibility for any advice, or recommentations, made by, or implied by, any member or guest vistor of HiFi Kabin that results in any loss whatsoever in any manner to a member of HiFi Kabin, or to any other person.
Furthermore, the Management of HiFi Kabin is not, and cannot be, responsible for the content of any other Internet site(s) that have been linked to from HiFi Kabin.
The images posted on HiFi Kabin may not be copyrighted to the posts author and are only posted here to reference the content of that post. As such HiFi Kabin acknowledges the true copyright owner in all cases. No other copyright ownership is implied.
