t-online.de
- Owner and Site Admin
t-online.de
If any of you are using an email address on t-online.de or plus.comyou may not be getting email notifications from The Kabin as for some unknown reason they are bouncing or otherwise blocking the majority of emails sent.
I am in communication both with them and Kualo (our hosting company) trying to resolve the problem.
I will update you once I know more
EDIT:- plus.com errors corrected
Re: t-online.de
plus.com issues now corrected, all emails should arrive safely now. t-online.de is still work in progress and I hope to have a resolution
Re: t-online.de
t-online.de issues now fixed, all emails should now arrive correctly. many thanks to Kualo for excellent support going above and beyond
Re: t-online.de
Two days on, and no emails bounced so the fix has totally worked. Its been a big relief
Re: t-online.de
...........The Kaptain wrote: ↑Fri Feb 09, 2024 7:18 pm Two days on, and no emails bounced so the fix has totally worked. Its been a big relief
Amp - Chord Ultima Integrated
Re: t-online.de
I have had to contact t-online.de again after a few Kabin generated emails were bounced back to me. The issue has now (or shortly will be) corrected by t-online.de
Deutsche Telekom AG wrote:Thank you very much for your message.
We will reset the reputation of this IP address with our systems. (Even
if this measure usually becomes operative in one or two hours, please
notice that it could take up to 24 hours depending on system loads.)
