[NOW SOLD] Goldnote PH10 phonostage.NOW ** £1000 **
Forum rules
Emporium Special Rules
1) This section is exclusively for the use of HiFi Kabin forum members. Only Full Members (those with 10+ posts) are allowed to start a Topic, all other members can reply.
2) No Fake or otherwise illegal items
3) For clarity it is best if ll For sale items include the price, a picture of the item with a piece of paper with your forum ID in shot.
3a) Members with the rank of Trade Member have their username coloured and only need to include the price and photo of the item.
3b) "Heads Up" and "Interest Check" posting is allowed without a photo, but a photo MUST be added before it is converted to a "For Sale" topic.
4) Any item sold for charity can be sold by auction if you wish. Set a starting bid, close date and state what Charity it is in aid of. All bids must be posted on the topic.
5) Please state FS, FS (CHARITY) or WTD in the topic title as appropriate.
6) Make it clear if the item is 'collect only' and/or where you are prepared to ship with an estimate of the cost.
7) Once the transaction is completed, please edit the title to indicate the fact
8) Neither HiFi Kabin the forum Admin or Mods can be held accountable for any transaction arising. This section has just been added to help members private transactions
9) Any listing that does not conform to the above may be removed without notice.
[Now sold] ** Price reduced **
For sale my fully boxed Goldnote PH10 phonostage. Purchased 29th March 2022. £1000.00 + shipping Location Mid Devon
I am only selling as I am having a Linn Urika 2 fitted to my Linn LP12. If required, it can be heard in my system until the Urika is fitted. This is the PH10 only, no seperate power supply which you can add for extra aural goodness!
Details of PH10 from the web.
An innovative and sophisticated phono stage permitting the ideal vinyl reproduction. Designed to achieve the best possible sound and total control over the listening experience, on PH-10 everything has found its rightful place: on the front panel the large TFT display shows all the settings information through an intuitive and easy to read graphic. PH-10 also features our Single Knob Control technology, an elegant solution to browse and change functions instantly that lets you enjoy the maximum of your audio system by finding the perfect match between PH-10 and your MM or MC cartridges through intuitive gestures, without the need to disconnect cables or adjust switches. It has never been easier to extract the most detail from your vinyl.
The Phono Stage of the Next Generation
PH-10 is an ultra-versatile phono preamplifier that offers unique features, including EQ CURVES, LOAD and GAIN adjustments: a fully analogue design engineered exclusively with high quality coils, capacitors and resistors.
You will finally be able to switch from the internationally recognized RIAA curve, to the DECCA-LONDON or the AMERICAN-CBS-COLUMBIA curve, always graphically shown on the front display. And there’s more, because you will also be able to “enhance” each curve with a modern Gold Note proprietary design for superior dynamic and powerful results.
The EQ curves are implemented using analog circuitry realised with last generation integrated circuits and low noise components because we believe in the absolute superiority of a fully analog design over digital equalizers. Instead of the antiquated and inefficient electromechanical switches, we opted for electronic switches to select the curves: in this way PH-10 can preserve unaltered the audio signal and safeguard its purity without giving up on the use of digital technology. The use of electronic switches also helps shorten the paths of the audio signal to obtain greater efficiency and less dispersion. Digital technology is used only for real-time management of the display.
PH-10 is controlled via knob and display using a sophisticated micro-controller to select the functions through our custom firmware that is loaded on a micro SD dedicated flash memory and can be updated easily via PC. The micro-controller is separated and independent from the audio signal path to guarantee always clear and pure sound.
PH-10 shows every detail on its 2,8” colour display powered by Gold Note proprietary SKC – Single Knob Control technology – an intuitive control system developed to easily browse and select all the unit’s functions. Once the tonearms are connected, PH-10 can be set with 4 different GAIN levels [-3dB, 0dB, +3dB, 6dB] to match precisely the output level of any MM or MC cartridge.
The perfect setup is guaranteed with 9 different LOAD options [10Ω, 22Ω, 47Ω, 100Ω, 220Ω, 470Ω, 1000Ω, 22KΩ, 47KΩ] that will let you adjust the preamp to match it with a large number of cartridges in a quick, easy way.
The unit can be externally powered by the dedicated external inductive power supply PSU-10 to enhance the performance even more .
Handcrafted in Italy with Passion and Technology
The secret behind PH-10? We design, craft and assemble every single part! Every PH-10 is handmade in Italy with the best audio grade components to ensure flawless music playback.
The level of quality meets the highest standard throughout the entire production: from the CNC machining to the assembly and finally to the electronic tests at the PC.
Linn LP12 keel karousel tramp, Urika 2, ARadikal2, Ekos se/1, dv-Karat 17dx
Linn Akdsm3 with Utopik
Goldnote PA10x2 (run as mono blocks)
Heed Obelisk dt dat
Kudos 606 + ks1
Various Audioquest tellurium and ifi connects
Heed Obelisk dt dat
Kudos 606 + ks1
