Correct me if I'm wrong, but I believe he meant the 360s are so good there's no need to see a band live. They turn recorded music into a live gig in your home.wildwildWes wrote: ↑Sun Jul 21, 2024 1:21 am Congratulations to akamatsu, vincent, and Baba Yaga! What an exciting time. Popcorn is popping for my vicarious pleasure.
Akamatsu I don’t understand your friend’s statement? What did he mean?
Linn 360s have arrived
Re: Linn 360s have arrived
Yes. Thanks Timster.timster wrote: ↑Sun Jul 21, 2024 6:10 amCorrect me if I'm wrong, but I believe he meant the 360s are so good there's no need to see a band live. They turn recorded music into a live gig in your home.wildwildWes wrote: ↑Sun Jul 21, 2024 1:21 am Congratulations to akamatsu, vincent, and Baba Yaga! What an exciting time. Popcorn is popping for my vicarious pleasure.
Michael
Michael
It's hard to imagine better. But we've all been there before. And thank you.
Michael
Michael
I really meant in terms of what you already have, playing with speaker position and SO etc. But, yes, we have all been there before
Linn Next Generation Klimax DSM System Hub Utopik
Linn Klimax Exaktbox Organik
Linn Klimax Solo Power Amps x 4
Kudos Titan 707 Speakers (Aktiv)
Listening last night, I'm still reluctant to touch anything in the way of speaker position. I'm thinking the speakers are a little too close to the front wall at 22 cm. Perhaps a couple centimeters out might help. I'll refine SO with wall, ceiling, and floor features next. It's sometimes tempting to hurry things. But a slow methodical approach is best I think based on past experience.
Michael
Michael
22 cm isn't really much, I would definitely experiment further out. Maybe you won't need SO...
Linn LP12 (Karousel)/Keel/Klimax Radikal 2/Urika/Ekos 2/Kandid/Linn Akurate DSM Katalyst/QNAP 219P II/Cisco WS-C2960-8-TC-L/Linn Akurate Tuner/1 x Majik 6100 & 1 x Majik 4100/Linn Akubarik (aktiv), Grado PS500e
That is awesome news! I guess that custom finish on mine really did delay things, a lot!Baba Yaga wrote: ↑Tue Jul 23, 2024 4:40 pm I just got a response by Gilad to my email.
My 360s were build today and will be shipped on Thursday (!) and therefore should be at my dealer first week of August. Wow…
BY
PS. Hope you don‘t mind Michael, that I post here rather than to open a new thread. This way our experiences will be documented and discussed in one place.
Yes, by all means post here.
Also, turn up the volume. You will truly be amazed!
Michael
Michael
Linn recommend a minimum of 23 cm for some of their speakers. But no recommendation for the 360s. Keeping the front plane of the 360s the same as was for the Akubariks has them land at 22 cm. I'll move them out a cm or two and see what happens. In the past, I've had better results with "speakers in ideal" in SO.Tendaberry wrote: ↑Tue Jul 23, 2024 4:16 pm22 cm isn't really much, I would definitely experiment further out. Maybe you won't need SO...
Michael
Michael
I would move them out in steps of 5 cm, but only as long as it gets better. As soon as it gets worse, move back to the previous position and then try moving out in smaller steps, like 2 cm. Continue this until you have narrowed it down to 1-2 mm.
Then the same for the distance between them and finally toe-in.
Thanks for this. Will give it a go. I'm not applying any toe-in, as I didn't with the Akubariks. I don't want the treble to be any brighter, and the dispersion of the tweeter is quite as advertised. But I may also give it a try as it might affect the imaging?Tendaberry wrote: ↑Tue Jul 23, 2024 5:03 pmI would move them out in steps of 5 cm, but only as long as it gets better. As soon as it gets worse, move back to the previous position and then try moving out in smaller steps, like 2 cm. Continue this until you have narrowed it down to 1-2 mm.
Michael
Michael
I initially had the Akubariks toed-in. I then removed it in order to tame the treble, which was a bit too harsh.
Michael
Michael
The dispersion characteristics of the 360s should be such that they don’t require toe-in.
Just MHO.
Just MHO.
No clicks at all over here.Baba Yaga wrote: ↑Tue Jul 23, 2024 6:43 pmI assume you haven‘t noticed a mysterious ‚clicking‘ when the speakers are warming up or cooling down?
My 350s were exchanged twice and still one has a slight version of this ‚clicking‘ problem. And even though I got used to it over the years I‘m looking forward to a ‚click-free‘ zone
Michael
Michael
Where are you measuring the 22cm from/to? Normally speaker measurements are from wall to front face. I haven't checked the specs but I would have thought the speakers themselves are more than 22cm deep?akamatsu wrote: ↑Tue Jul 23, 2024 4:54 pm Linn recommend a minimum of 23 cm for some of their speakers. But no recommendation for the 360s. Keeping the front plane of the 360s the same as was for the Akubariks has them land at 22 cm. I'll move them out a cm or two and see what happens. In the past, I've had better results with "speakers in ideal" in SO.
Klimax RDS/1 > Klimax Kontrol > Klimax Twin > Klimax 350p's
Measured from the back corner. This is the point from which to measure distances with the 360s. Height is measured from the bottom of the 20kg base. The speakers are definitely deeper than 22cm, but they are only 2 cm deeper than the Akubariks, not counting the base.entdgc wrote: ↑Tue Jul 23, 2024 9:51 pmWhere are you measuring the 22cm from/to? Normally speaker measurements are from wall to front face. I haven't checked the specs but I would have thought the speakers themselves are more than 22cm deep?akamatsu wrote: ↑Tue Jul 23, 2024 4:54 pm Linn recommend a minimum of 23 cm for some of their speakers. But no recommendation for the 360s. Keeping the front plane of the 360s the same as was for the Akubariks has them land at 22 cm. I'll move them out a cm or two and see what happens. In the past, I've had better results with "speakers in ideal" in SO.
Michael
Michael
I probably wouldn't apply toe-in, as many have said. I had 2 mm toe-in for my Akubariks for years, until I tried no toe-in again and the sound just "clicked".
What's your current streaming to vinyl percentage with the 360s? Did streaming time go up or down versus the Akubariks?
Linn LP12 [Krane, Adikt, Trampolin, Karousel, Akurate Radikal1], Lejonklou Slipsik 8, -> Linn Klimax DSM 3 Hub [Utopik] -> Linn Akurate Exaktbox-I [Katalyst] -> Linn Majik 140s
I'm DSing more now compared to with the Akubariks. I'm still spinning LPs in the evenings. I'm just DSing more during the day. Both formats are so enjoyable.wildwildWes wrote: ↑Sat Jul 27, 2024 3:12 am What's your current streaming to vinyl percentage with the 360s? Did streaming time go up or down versus the Akubariks?
Michael
Michael
I'm here. I had come down with a bad case of Olympic fever. Lasted about two weeks.
I'm still stunned and rather speechless about what I'm hearing at home. Every album I play is a new experience. Both streaming and LPs are fantastic.
I'm looking forward to your impressions, coming from 350s. I have to say that as good as the Akubariks are, the 360s are a huge step up.
It's hard for me to collect my thoughts and write a cohesive review. Perhaps I'll just post random observations and experiences with the system.
Michael
Michael
Woohoo!
Looking awesome!
Perhaps we can share notes on speaker locations. I haven't moved mine since initial positioning since it sounds so amazingly good. But I intend to move them out from the front wall. I see yours are pretty far out.
Congratulations! Our systems are practically identical. You have timetables, and I have AudioTech and NOKTable.
Looking awesome!
Michael
Michael
That's one nice set-up you have there. And, great pictorial story - love it.
If it were me I'd have the LP12 front and centre but that's minor nit-picking from me
Turntable - Linn LP12, Karousel, Keel, Ekos SE/1, Krystal, Lingo 4
Phono Stage - Uphorik
Amplifiers - Klimax Kontrol (KK/1 Dynamik), 2 x Klimax Solos (Dynamik)
CD Player - Arcam
Speakers - PMC Twenty.23
Cables- Linn K200 Speaker Cable, Linn Silver Interconnects
Support - Sound Organisation (LP12), Quadraspire
CD Player - Arcam
What I find interesting is that Baba Yaga and I both have our components on their own stands in the same positions. This happened by coincidence. In my case, I want the LP12 to be furthest from the speakers. The Radikal and DSM fell into place after that.
Michael
Michael
Doggy approval is the best confirmation
CD Player - Arcam
CD Player - Arcam
They look stunning @Baba Yaga. Lovely finish.
Just out of interest, is there a minimum room size for such speakers? I imagine even if my room could allow for better positioning, 4m x 4.5m is probably too small!
Great photos Baba, they look magnificent - do keep us posted how the sound develops!
KSH(2018)/Utopik Exakt Akudoriks/Katalyst
